It is currently Sat Aug 02, 2025 8:16 pm
 Post subject: Salty air
PostPosted: Fri Feb 22, 2019 2:52 pm
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
So the family and I vacation in key west for two weeks in February every year. There is a musician down here that I plan on building a guitar for...he doesn’t know it yet, it’s going to be a surprise. I’m just going to give it to him.
Anyway, We were at a restaurant yesterday and I saw a guy performing and noticed his binding had come apart on both sides in the waist. Upon talking with him he had said it was because of the air down here.
My 2 questions....
Has anyone heard of this?
and more importantly...
What steps does a luthier take in combating this situation?
Thanks in advance.
 Post subject: Re: Salty air
PostPosted: Fri Feb 22, 2019 4:02 pm
Never let a non-luthier diagnose the cause of guitar damage.
These users thanked the author Barry Daniels for the post: Bryan Bear (Fri Feb 22, 2019 4:51 pm)
PostPosted: Fri Feb 22, 2019 6:07 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
More likely the type of adhesive. I’ve had fish glue fail before but nothing else. Now I use titebond & superglue
PostPosted: Fri Feb 22, 2019 6:24 pm
First name: Brad
Last Name: Combs
Key west - Leave the guitar in the car for 5 minutes. Come back to an LMI pre-serviced kit. All the parts you need to build your own geeetar. :D
These users thanked the author bcombs510 for the post (total 2): muse (Sat Feb 23, 2019 3:54 pm) • Bryan Bear (Fri Feb 22, 2019 10:03 pm)
PostPosted: Fri Feb 22, 2019 8:55 pm
Salty air along the coast line is not good for iron or steel but I don't think it would have any impact on glue joints, other than the normal effects of high humidity.
PostPosted: Sat Feb 23, 2019 2:27 pm
Last Name: Beaver
City: Lake Forest
Humidity and heat alone will do the trick but if you want it amplified try taking a guitar quickly from a cool, dry AC environment to humid hot one.
I build in a usually dry environment. Here are the things I do when I know the guitar will live in a hot, humid one:
1. use a moisture stopping finish. Most common finishes are poor at that, including shellac, water based and nitro. The newer urethane stuff does the job, so does using epoxy as a pore filler. I haven't made the jump to urethane so I go with the epoxy pore fill, including a very thin coat on the top. 2. Seal the inside of the box with a thin layer of rattle can urethane. It may have a slight tone robbing effect but just slight. 3. Use Carbon Fiber in the braces, such as a sandwich of spruce with CF in the middle. 4. Stay away from organic glues. Go with aliphatic resins, and CA here and there as needed. 4. Encourage the owner to leave the instrument in the case for as long as possible when moved to a different environment. That will give it a better chance to acclimate.
I suspect these are not going to be popular choices but they work for me.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Bri (Sun Feb 24, 2019 4:04 pm)
PostPosted: Sun Feb 24, 2019 3:25 pm
I can see this happening down here.
I spend winters here and the humidity and salt air do strange to things.
In my house one of the biggest things that happens is the soles of shoes, sandals, and anything with rubber on them come unglued. You can be walking along and the sole pops off. Has happened to Keen, Timberland, Merrill.
I have had stuff under the house come delaminated right on the glue lines. Have used titebond, CA and some epoxies.
It hasn't happened to any of the guitars that I built but they stay in the house with the A/C on
Just my 2 cents from someone that has lived in the keys for almost 28 years.
Gary
PostPosted: Mon Feb 25, 2019 11:09 am
First name: George
City: Seattle
That's just the gods telling you to wear flip-flops.
George :-)
PostPosted: Mon Feb 25, 2019 1:09 pm
Last Name: Beaver
City: Lake Forest
I think you could be on to something George. bliss
Joe Beaver
Maker of Sawdust
PostPosted: Mon Feb 25, 2019 1:13 pm
Forgot about those.
Timberland sandels blew out on Boac Chica beach once...
PostPosted: Wed Feb 27, 2019 8:24 am
Salt air it ain't thin,
It can stick right to your skin and make you feel fine
Makes you feel fine.
PostPosted: Wed Feb 27, 2019 11:36 am
Last Name: Beaver
City: Lake Forest
I can stick right to your skin and make you feel fine
Jimmy speaks the truth
Joe Beaver
Maker of Sawdust
PostPosted: Wed Feb 27, 2019 1:04 pm
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Don't neglect to seal the inside of the guitar.
